I'm trying to download a map in Collector that has one feature service that contains a point feature class and a related table.
I am using AGOL hosted feature services that I created from a file geodatabase in ArcGIS 10.3.1. For Collector, I'm using it on an iPhone with iOS 8.4.1.The map download seems to fail no matter the area I try to download, and I have checked for bad geometry using the Check Geometry geoprocessing tool and there aren't any issues there.
I have attached a screenshot of the error message which says "Unable to create replica. Please check you parameters. Exporting data for layer 1 failed."
I tried a suggestion from another post of going into the item details of the map and disabling the Offline Mode property, then re-enabling it, and re-sharing it with my appropriate user groups, but that did not fix my issue.
Kerry
Solved! Go to Solution.
Kerry,
The issue is related to invalid field name. Layer 1 (LAKE_HYDRO_WaterQualityMonitoringResults_tbl) contains invalid field names (Water_Temperature_°C, Air_Temperature_°C). The workaround is to change Field name into others like Water_Temperature_Celsius.
Kerry,
You can try to use fiddler to capture request parameters on Create Replica requset following http://blogs.esri.com/esri/supportcenter/2011/12/06/configuring-fiddler-to-capture-web-traffic-from-.... We might have more insight of the issue. It might be related to related table you set.
-Morgan
Kerry,
You can share your map to a group and invite the account Collector4ArcGIS into it. I can take a look.
-Morgan
I have invited you to the LAKE_WaterResources group. The name of the map is Water Quality Monitoring.
I can reproduce the issue. The development team is aware of this issue now.
Kerry,
