make map for collector
3473
8
12-14-2017 11:47 AM
MatthewGondek
I have created a map and shared it with my group.  My group is not showing up in collector nor is my map.  Help.
Tags (1)
Kylie
by Esri Regular Contributor
Do you have an editable layer in your map?
Esri Education Team
MatthewGondek
As in I can open my map in Map Viewer and select edit and add points?
MatthewGondek
If so than yes
Kylie
How did you create the layer of points? They need to be a hosted feature layer or an ArcGIS Server feature service.
Supported data—Collector for ArcGIS | ArcGIS
Esri Education Team
MatthewGondek
I created a shapefile, then used editor to create two sample points.  I then zipped the shapefiles and uploaded the file in Map Viewer.
MatthewGondek
So I uploaded the shapefile to ArcGIS online.  So now it is a featured layer hosted.  Do I publish it?  And what do i publish it as?  A tile layer?  I am doing data collection on bird nests and I just need to be able to add a point to where the nest is for reference.
MatthewGondek
I think I figured it out!
Kylie
Great, I'm glad you got it working. If you could, please summarize what you did so that others who hit the problem will see how you solved it. Thanks!
Esri Education Team
