Issue w/Setting Up GDB for Use in Collector App.
2950
03-03-2015 02:01 PM
AnthonyRyan2
I have setup a gdb with a few feature classes that have field labeled, some w/domains. I load it to ArcGIS online and add to a new map with editable capabilities. I open the map in the collector app and see the map. However, I have no collect new tool showing "+". Why is this? did I miss a step in setting up the gdb or loading it to ArcGIS online?
Also, the attributes for each feature are not populated. I wanted this to be blank until data was added through the use of the collector app.
