How prevent Collector use my current location on the base map?
815
05-02-2014 01:44 PM
OscarRodriguez
When I load my basemap, Collector places the map in my current position. I want to locate me within map in a place already set.
How I can prevent Collector use my current location?
thank you guys!!
RussRoberts
Esri Notable Contributor
You can disable location services on the device or you can turn the GPS off by tapping the GPS button on the toolbar. You can also leverage the GPS on and you can access the maps default extent or area taken offline by going to the bookmarks tool and the first entry in the list will be the default extent.
Russ
