basemap transparency
1308
04-07-2014 05:35 AM
AdrianMarsden
Honored Contributor
Hi - see image
[ATTACH=CONFIG]32868[/ATTACH]
A offline basemap created as a Tled Package from ArcMap.  Because it is vector the empty space is being rendered as transparent, showing the default grid below.
Is there any way to avoid this - APART from creating the package in a format, like JPG that doesn't support transparency.
Cheers
ACM
AdrianMarsden
Honored Contributor
Ok - as no-one answered this I spent a day (of server time) generating a new tile package with a solid white polygon under everything else.
Then, before I could load this file on, guess what happened ?  The latest version came out and the annoying grid had gone, so my existing package worked.
How dare you fix things like this 🙂
AdrianMarsden
Honored Contributor
