Has deeplinking from Collector to Survey123 stopped working for anyone else on iOS?
3250
13
12-18-2016 11:59 AM
Guidovan_der_Kolk2
We have a webmap that we use from Collector to open up a Survey123 form. It seems to have stopped working on my iPad. It still works when I open the webmap in Explorer on iPad. It also still works from both Explorer AND Collector on Android. Is anyone else experiencing this issue?
IsmaelChivite
Esri Notable Contributor
Hi. Collector for ArcGIS 10.4.2 is now available in the iTunes store. This version includes a fix to the deep-link capability.
Guidovan_der_Kolk2
A lot of thanks for the quick action! You guys deserve a merry Christmas now.
MarkSlaten1
Kudos to your team for fixing this so quickly- testing 10.4.2 confirmed that the URL links are working again.  Thank You!
mark
JadeFreeman
I'm having a similar issue with 10.4.2 (iOS) except in my attribute template popup, I'm configuring links to open other maps in Collector (i.e. arcgis-collector://?itemID=XXXXXXXX).  If I long press on one of these links and choose the copy option then paste the link into Safari it successfully opens the new map in collector.  I have seen in other posts that Collector now opens all urls in an exteranal browser (Safari) but this does not seem to be true - 10.4.2 still opens them in a Collector browser window.  I suspect if it opened them in an external browser, the custom url scheme would work.
