Geoform vs Collector
3447
10-21-2014 07:57 AM
MikeOnzay
How is Geoform different from Collector? Are they complementary?
Tags (1)
AnthonyGiles
Honored Contributor
The major difference is that collector allows you to work offline but with the GeoForm you need to be connected. I would say they both have different uses collector is targeted towards the mobile device where the geoform is more for access where you have a constant internet connection
TobiasFimpel1
To add to this: to use Collector against a web map you need to authenticate to an ArcGIS organizational account or portal. This is not the case with the Geoform.
