Feature Services labelling in Collector 10.3
7771
10
03-10-2015 09:20 PM
YuanGao5
Hi ArcGIS Gurus
I understand Feature Service Labelling is not supported in previous Collector versions but is it still the same for 10.3?
What I am trying to do here is to digitize a line feature in Collector, set a value in a field called "Length" and I want that value to be displayed on Collector. If Collector 10.3 doesn't support labelling for Feature Services, is there any work around?
Many thanks
Yuan
PeteCrosier
Esri know that it works, but I imagine they are very wary of saying that too loudly. Hopefully the real implementation of labelling, if it comes, will just replace the unofficial version with an update. The problem would come for Esri if they had documented the way labelling currently works and then had to remove it from Collector without a replacement implementation. Not saying this would happen, but it seems Esri are playing this one cautiously.
You could maybe disable your scripts and use offline labelling, then you've always got your scripts as a backup?
