Error "Edit Not Applied" when collecting with the Collector app (Android)
1644
10
06-28-2013 07:59 AM
MikeGarza
I have a service that I am publishing in ArcGIS online. I can collect on any of my published layers with my iPhone collector app but when we try to use our Android phone it will only collect on one layer. We keep getting the error messsage "Edit not Applied" with the Android app.
Has anyone run into this issue? The Android phone is a new phone with the latest software.
Any info would be a huge help.
Mike
DossDingli
Actually, I did fix it.  I did turn the sync off but still received the error. This only occurred after repeated, "Popup contains invalid value" errors.  So, I modified the map by making sure that the primary key of the shapefile (feature service) wasn't in the pop up any more.
This cleared both issues so far.  I have not turned sync back on to see if it creates the issue again though, but will probably try at the end of next week.
