Do side loaded TPKs with scale dependencies work?
2991
04-29-2014 11:25 AM
DougBrowning
MVP Esteemed Contributor
We have a large 9 gb TPK that we have been using with another mobile app.  It has scale dependencies where when zoomed out it gives a topo and then when zoomed in it gives our own imagery.  Works great in other app.
In collector I can side load it and select it as a basemap fine.  But when I zoom in it never changes to the imagery.  Stays with a now rather blurry topo.  My web map is set to a basemap of imagery so I know it is using it, it will just not change when zooming.
Should this work or is it not supported?
RussRoberts
Esri Notable Contributor
You can only use one basemap at a time in  a disconnected map in the Collector. The basemap you choose when downloading the operational data will be the one displayed in the disconnected map. We are working on improving this experience and bringing in the functionality of switching basemaps.
You could set up the Esri layer as an operational layer with scale levels at the bottom of the layer control and then have your other basemap ready on device and you can then use the custom basemap to define the extent and download the data. All tiled services being used however will need to be in the same projection which is Web Merc.
Russ
DougBrowning
But it is not a different basemap it is all one big TPK.  It just switches from topo to imagery but is all packaged into one file.  Does it just ignore the scale stuff?
DougBrowning
They are not separate basemaps -both the Topo and imagery wrapped up into one tpk file.  Does this not work?
RussRoberts
Can you send us the mapserver.json file and the conf.xml from inside the tpk to [email protected] and we can take a look at those files and determine what the issue may be.
Russ
