The Collector for ArcGIS FAQ says that you cannot edit disconnected versioned data unless you are using ArcGIS 10.3 and SDE 10.3 . However, it doesn't mention if you can do it in ArcGISPro. Also, when searching to see if this question was asked already, I came across several discussions saying that you could do disconnected versioned editing in 10.2 . Maybe I misunderstood? What's the definitive answer - 10.3 or 10.2, and can it be done in ArcGISPro? Thanks!
