Demo App or real?
1389
13
01-15-2013 12:40 PM
LukePhilips
Is it possible to use this app with my own arcgis online account or arcgis server? It seems like the app is only a demonstration...
PaulBarker
lukepatrick,
Thanks for the question, yes this is a real app and not a demo. More information and resources are in the process of rolling out over the next 24hrs to help you get started with the Collector for ArcGIS.
ErnestoCarreras3
I followed the instructions described in order to set the Track Location but after re-saving the map, the properties were not displayed. Also, I shared the map, generated the link and sent it via email. Once received and clicked to open, it never requested to be open using the Collector for ArcGIS app nor was not able to open it from the app itself.
Is it a ready-to-use app or is it still under development?
AkosKisreti1
The link didn't work for me either. You should try to copy and paste the link from the email to your browser, this way I could manage to open the map with Collector app.
I used this schema: arcgis-collect://www.arcgis.com/sharing/rest/content/items/<map ID>/data
ErnestoCarreras3
Thanks! It did actually worked that way. Anyone knows about the Track Location issue? Has it been deployed in AGOL already??
RussRoberts
Esri Notable Contributor
You will need to have an ArcGIS Online Subscription account to publish a hosted feature service that is configured to be a tracking layer. Here are the steps below on how to create this layer and configure it once your map is created.
http://resources.arcgis.com/en/help/collector-ios/index.html#//02s20000000m000000
Hope this helps you out.
Russ
DavidAlford1
It doesnt work on either Android or iOS.
Here is my link
http://bit.ly/WdlRmh
DavidAlford1
Or this one either!!!
http://bit.ly/WdpHfb
RussRoberts
The org or link you pasted is not shared so I cannot access the map to see what is wrong. If you want you can invite mobileios to the group with the map in it and I can check it out.
Thanks
Russ
