Collector Related table to Nested Related table?
1296
12-27-2016 10:40 AM
deleted-user-8zpXkQfV8bQC
I have a point feature in Collector that has a related table (GlobalID, GUID) for manholes.  I have to submit the manhole (point) feature first, then go back and EDIT the point to get to NEW related table for manhole type and attributes.  However, can I relate the manhole type table to another table?  This second related table is more for diameter of manhole.  So, for example, I will put in a manhole type in first related table, then in the second related table, based on the type I put in, can it only give me the specific type diameters?  Like, manhole type 'steel' and therefore once I select steel, submit and then go to steel and select a diameter in the 2nd related table like 2" to 2.5 OR "3" to 3.5".  Since coated steel could have a completely different diameter size.  Not sure that is possible?
DanPatterson_Retired
moved to https://community.esri.com/community/gis/applications/collector-for-arcgis?sr=search&searchId=32cd14...‌  the question was in GeoNet Help... which is about help on GeoNet
