Is there a way to limit the number of columns from the database in collector app so that the field crew can only see and enter information for specific fields rather than all domains? Also is there a way to order how they are displayed or is that dependent on how the database is set up?
Solved! Go to Solution.
As you author the map, you can configure the data collection form. See "Configure the data collection form" in Create and share a map for data collection—Collector for ArcGIS | ArcGIS. When you are configuring the pop-up, you set what fields you want to show, as well as their order.
