Collector and Tables Relationship class
11077
22
07-30-2018 08:46 AM
SiranErysian2
Related Tables in Collector: Spoke to Jeff Shaner and others at ESRI Conference 2018 and it was suggested that I use the Global ID field as the Primary key when joining a stand alone table with point feature class in map service published for Collector. Is this when the Global ID field is established? My table does not have a global id field. I have another field that I proposed to use that is in both the table and the feature class attributes. Why Global ID is suggested to use? Do I need to create a relationship between the table and the feature in the geodatabase for the table to appear in Collector?
deleted-user-qpvAI3Fo0MKR
If you want to invite me to your ArcGIS Online group I'll have a look, it'll be much easier for me to investigate your issue that way...
SiranErysian2
Is this the address I put in?
jschwartz@fcgov.com_fcgov<mailto:jschwartz@fcgov.com_fcgov>
Siran D. Erysian, M.A., GISP,
Research Analyst II – GIS
Think Spatially
Department of Water Resources
3374 E. Shields Ave, Rm. A-1, Fresno, CA 93726 (559) 230-3312
Siran.Erysian@water.ca.gov
jschwartz@fcgov.com
SiranErysian2
Modesto GWB is the hosted feature layer. Modesto test is the map
Think Spatially
OK cool. I see the map in Collector. When I click on an asset (Well), I can view the related records. This is the expected behavior. What is not working the way you would hope?
SiranErysian2
So if you click on the work Show in the field Data Associated with Wells in the ModestoGWELEV related table, you see 3 values
So this is what the field worker will see? Is it possible for 3 fields to show here? I’d like the Date, Reading@ RP and NM Code (that’s if there is no reading that day, the reason why)
I set this up in the identify display in Arc Map so I was wondering if there was a way to show this in a table?
I haven’t’ looked at this in Collector yet. Can you give that a try and let me know what you see? I use iOS iPad for my Collector and I’ll do that shortly also.
Thanks again.
Think Spatially
What you're describing is the expected behavior. When you click on the asset (Well) you'll be able to view the list of related records, then your crew will need to click on the individual records to see the actual related record itself. This is how it works. Does this make sense?
SiranErysian2
Yes. I think I’m good to go!
Think Spatially
Great, glad to hear it. Please don't forget to remove me from your organization
SiranErysian2
Done!
Think Spatially
