Collector and offline capabilities
644
07-24-2019 07:13 PM
JanettePerez-Jimenez
Hello! I am new to collector, and I downloaded a section of a larger map to work with for ease in the field. But now when I open the map it only shows me that section that I downloaded and not the rest of the map.... any tips on how to reset it so that I can view the rest of the map and not just the section I downloaded
DerekLaw
Esri Esteemed Contributor
Hi Janette,
After performing your offline data collection, did you perform a sync operation and then remove the downloaded map area?
Sync and manage offline map areas—Collector for ArcGIS | ArcGIS
Hope this helps,
DerekLaw
Hi Janette,
Hope this helps,
