Collector 10.3.1 on iOS can't add new points!!
9115
11
06-17-2015 01:22 AM
YigalMuntner
I have upgraded the Collector for iOS to 10.3.1.  I have a web map with feature services that I need to update. ArcGIS Online basic viewer can edit the features, as wel as the Collector on Android devices. On my iPAD the 'Submit' button is grayed out and I can't submit any record. Any clue??
MiaogengZhang
Can you check if all the required fields for the point are filled up?
JeffMinichiello1
Having the same issue with with Collector 10.3.9. All of the fields have been filled out with the correct data types. Only having this issue on select services. This problem is only happening on our IOS devices, android is working with the same services just fine.
JeffMinichiello1
The solution for me was to make sure that any auto-generating fields like Created By, Edited By, Edit date, have "Allow NULL Values" set to Yes.  That seemed to do the trick.
PublicGardens
Greetings,
I am having the same issue with IOS devices only.
Did u find any solution for this ?
i will appreciate your help
GISSupport3
What happens now if you share the map?
PublicGardens
no changes ... cant add  points
GISSupport3
Do you have a scale threshold ... does the + button appear if you zoom in?
PublicGardens
yes
GISSupport3
Every (required) field has valid data?
