capture accuracy of collected data
2363
05-01-2014 04:43 AM
douglascurl
Simple question - I'm pretty new at this, but is there a method or is it possible to capture the collector accuracy into the geodatabase? Say, I want the point collected to be attributed with an accuracy of, say, 10 meters. I guess the other way to go about this is to setup the collect settings for users, so that you know that all points collected were within a certain accuracy range. But not sure exactly where those settings are set for other users so they can't change them.
RussRoberts
Esri Notable Contributor
Currently only the location tracking layer supports adding the GPS accuracy value to a feature.
Cheers
Russ
