Adjustable-size scrim appeared on bottom of Collector screen blocking map access
524
10-09-2019 09:06 AM
MikeTschudi
Esri Alum
Attached screenshot shows the top of the scrim highlighted with a yellow oval.  Below the scrim, the map was unresponsive; had to drag it down via the top line to regain touch access to the map.  White/blue add button slid down with top of scrim.
Couldn't reproduce it.  Best that I can tell is that I was trying to clear the last-entered point display so that I could enter a second point.  Lots of poking and dragging of bottom window.
Collector 19.1.0.2666, iOS 13.1.2, iPhone XR
