Adding tool box functions to collector?
936
04-22-2014 01:52 PM
CoryOverton1
This may be a bit too much for me to actually implement, but I had questions about adding toolbox functionality to collector apps.  Specifically, I'm interested in adding a "Bearing Distance to Line" function that can be applied as data is collected in the field.  Essentially this would make both point data containing attributes entered by field personnel (including a "bearing" field) and a line extending a default distance from that point along the specified bearing.
Is this even possible?
RussRoberts
Esri Notable Contributor
You currently cannot extend the collector app. I would recommend logging this under ideas.arcgis.com and we check out that site to see any enhancements we can make to the apps.
Russ
