It would be very useful to be able to access URL params passed to Collector via a dictionary in Arcade Expressions.
It is very useful to be able to pre-populate data in Collector via the URLs featureAttributes parameter but that value does not persist past the initial feature.
I want to be able to use those values to default all features captured in a session. The use case is:
Survey123 could have similar implementation by accessing properties using pulldata("@params",'featureAttributes')
