webscene and transparency
6386
9
05-08-2014 03:24 AM
johnbrosowsky
In my city engine scene I make rooftops transparent in order to see into the buildings from the top.  When I export to a web scene, the rooftops in web viewer are solid.  How can I make the web scene observe the transparency?
LukeCzar
Hi John,
How did you make them transparent? is it a sketchup model? did you use RULES to make those building transparent?
Lukasz
johnbrosowsky
I imported a shapefile containing building footprints, and then used a simple rules cga to extrude the building footprint polygons, and assign color and opacity to floor, roof, and walls:
attr Height = 10
@StartRule
Lot--> extrude (Height)
comp(f){side: Facade | bottom: Floor | top: Roof}
Roof -->
set(material.color.a, 0)
color("#CDB38B")
Facade -->
color("#909090")
Floor -->
color("#F7F8E0")
MatthiasBuehler1
try :
set(material.opacity, 0.3)
matt
johnbrosowsky
It still does not work.  I see the partial opacity in the City Engine desktop, but in exported web scenes or collada models.
MatthiasBuehler1
can you post some precise screenshots of what needs to be transparent and how it looks both in CE and in the WebScene ?
are textures involved that need to be transparent ?
let me know ..
matt
johnbrosowsky
There are no textures.  I imported a shapefile of building footprints, extruded into 3D, and set the top to be transparent using the simple CGA rule I pasted above.  Attached are pictures.  The .cej shows a transparent roof.  When I export to 3ws or collada the roof becomes solid.
MatthiasBuehler1
sorry for the trouble...
can you please try 1 single rectangular shape with this code:
Shape -->
      extrude(5)
      set(material.opacity, 0.5)
this should work in any case. it works for me here.
let me know ..
matt
johnbrosowsky
That works!  Is it possible to get the polygons extruded from the imported shapefile to look the same?
Thanks a lot!
MatthiasBuehler1
Sure .. that should work.
So it seems something goes wrong with your CGA code ..
Just copy-paste my code into your code and this should work then.
Maybe start a fresh rule with this as a base. ok ?
Matt
