eclipse.buildId=unknown CityEngine crashes!
5963
05-15-2014 09:17 AM
KennethLindhardt
I have had this issue a couple of times, to begin with I recreated my scene, but I don???t think I would like to do that every time.
What I???m doing at the moment is, that I need to delete that scene it is trying to load, or copy it to the desktop. Then I can start CityEngine, paste my scene back in, restart CityEngine, and then it will work until next time I close CityEngine, then I need to do the procedure again. Is this something that I can solve?
java.version=1.6.0_43
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=da_DK
Command-line arguments:  -os win32 -ws win32 -arch x86_64 -data @noDefault
Error
Thu May 15 19:02:34 CEST 2014
Failed to execute runnable (java.lang.NullPointerException) (SWTException) - [main]
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:4282)
at org.eclipse.swt.SWT.error(SWT.java:4197)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.corebounce.rcp.CBDisplay.readAndDispatch(Unknown Source)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.procedural.cityengine.release.Application.start(Unknown Source)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Caused by: java.lang.NullPointerException
at com.procedural.ceui.inspectors.CGAAttributeInspector.getStyles(Unknown Source)
at com.procedural.ceui.inspectors.CGAAttributeInspector.changed(Unknown Source)
at com.procedural.cga.CERuleFile.invalidate(Unknown Source)
at com.procedural.cga.CERuleFile$1.resourcesRemoved(Unknown Source)
at org.corebounce.io.ResourceMonitor$1.run(Unknown Source)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
... 23 more
MatthiasBuehler1
hey ..
try :
- creating a new workspace
- deleting the '.cityengine' folder in your user account
let me know if this helps !
matt
