Water rendering
5283
10-16-2014 08:50 AM
FloreStuby
How to modelize a water surface in CityEngine ?
DavidWasserman
Generally in the model view, people apply a texture to a surface with a bump map. Just Google water bump map textures and lots of general options appear. You can apply a bump map somewhat like a normal texture, see help link below.
Help -
More information on bump maps:
Bump mapping - Wikipedia, the free encyclopedia
For web scenes we have an active water rule, while you might need another jpg, the general code is attached.
I hope this helps.
David Wasserman, AICP
FloreStuby
Thanks for the information !
by Anonymous User
Not applicable
Attached is a cga rule that applies a water texture, and it names the material so that in web scenes the water is animated. The texture is also attached. I have no idea where the water image came from, or if it is owned by anyone.
FloreStuby
Thanks for your help !
It works.
