Visual CGA not working in 2023.1
515
5
05-23-2024 09:32 AM
ChristopherKowal2
I am having trouble starting the VCGA graph. When I  start the (VCGA_Designs/Video_Tutorial/VCGA_First_Steps_Building_Part1.vcga) rule it creates the 3 houses in the viewport, but when I go to the graph view I get this error.
Is 2023.1 not supported? I have tried to repair my install but I get the same results. Any Ideas?
ChristopherKowal2
When I open Melton_Scene_Building I see the graph... odd
JonasObertuefer
Hi @ChristopherKowal2,
You can run into this issue in 2023.1 after you initially download/add the example project to your workspace and then open up the design for the first time. When you you close the VCGA file and reopen it should load correctly.
The issue is fixed for the 2024.0 release. If you are interested in VCGA I encourage you to try out the 2024.0 beta which is currently running.
Cheers
Jonas
ChristopherKowal2
Thanks @JonasObertuefer ,
I received an email mentioning the 2024 beta but there was no DL link, nor can I find it in my dashboard.
ChristopherKowal2
Early Adopter...
ThomasFuchs
Here is where you will find the beta version download on Esri Early Adopter
