Using Redlands Example rules in CE 2014
15719
24
07-30-2014 02:16 PM
NeilBorecky
Is there an update to the Redlands example 3D City Design Rules to work with City Engine 2014? The Street Construction rule has problems including not generating crosswalks, and textures appear to be offset, making parallel parking disappear. Image of the issue attached.
CherylLau
CityEngine automatically determines the appropriate version of the example to download if you download the example from within CityEngine.  Help -> Download Tutorials and Examples.  Did you try to download the example through this dialog box?  I just tried it on 2015.2, and I didn't see any errors in the Problems view.
by Anonymous User
Not applicable
Ziad,
Sorry about the delayed reply. The 2014 version had an error in Street Construction.cga, due to a slight change in CGA syntax for the split operation. That error is now corrected in the downloadable version here: http://esricityengine.maps.arcgis.com/home/item.html?id=9008aa9c322340edb2382f599cb3fb86
Also, I've attached the erroneous rule to this reply.
Thanks your patience and for reporting the bug,
Chris
ziadfilfili
Chris,
Thank you it worked
cheers
JavadSalimi
Hi Chris,
I followed the link you provided but it takes me to a "Sign in to ESRI City Engine Team" page where my arcgis.com credentials are not being accepted. I too would like to see if the rule file you updated works with 2015.2.
Thank you,
Javad
CherylLau
To get Chris's exact file, you can download the attachment he attached.
Here is the link to the same example for 2015.2:
http://www.arcgis.com/home/item.html?id=4b928739ca7c4effa11ee29530419057
and for 2016.0:
http://www.arcgis.com/home/item.html?id=f4011b7c5d86407c9737733371ca01a6
This example is also available through the download dialog within CityEngine (Help -> Download Tutorials and Examples).
