Using Redlands Example rules in CE 2014
15680
24
07-30-2014 02:16 PM
NeilBorecky
Is there an update to the Redlands example 3D City Design Rules to work with City Engine 2014? The Street Construction rule has problems including not generating crosswalks, and textures appear to be offset, making parallel parking disappear. Image of the issue attached.
by Anonymous User
Not applicable
Tatianna,
Good to hear about the Geodesign course! I had not tried running that rule on a footprint. Thanks for reporting it. I'll go try and fix it. Either in next 20 mins, or will have to do it tomorrow.
by Anonymous User
Not applicable
Ok, got it fixed!  Please replace your Building Construction rule with the updated rule attached here. Let me know of further problems.
Chris
TatiannaSwenda
Thank you very much!
Sent from my iPhone
by Anonymous User
Not applicable
Another bug was reported to me. This one, as well as the one Tatiana reported, were seen when applying Building rule to a drawn shape, rather than street network-derived shape. Hers was using Footprint start rule. This one came from using Parcel start rule. The buildable envelope and building setbacks were not working correctly. The attached rules folder fixes this and has the most up to date rules for Example Redlands 2014 as of 8-8-2014. (only Building Construction.cga and Support>Zoning.cga have changed here)
KathrynAngleton
Where can I find a zip of the Redlands assets folder? All I can find in this thread and on the Redlands link is the rule files. I lost my original copies of the rules and assets.
by Anonymous User
Not applicable
Here's the entire project:
http://www.arcgis.com/home/item.html?id=9008aa9c322340edb2382f599cb3fb86
The rules and assets are there, and the scene showing their use.
Chris
NathanEnge
Neil Borecky    did you get it working?
ziadfilfili
Is there an update for the red developments to use in 2015.2 ?
I am facing problems with executing the rules
ERROR: ( the rule file 'building construction.cga' contains errors. check the 'problems view )
any ideas ?
Many thanks.
by Anonymous User
Not applicable
ziad,
Are you seeing the errors in the downloaded Example project? Or are the errors in another project in which the rules were used?
Chris
ziadfilfili
The errors are actually in both, my project and the example project
Maybe it needs update to city-engine 2015.2
Ziad
