Using CGA how can I insert a OBJ model over a textured flat shapebase without having the base disappear?
2843
07-27-2017 11:10 AM
CarlaBernecoli
Hi all
I am trying to write a rule that assigns a random  ground texture for each lot and inner lot and then inserts on top of them a random OBJ shape  in the centre of each lot (in my case specific houses and towers models I prepared).
Using the insert rule causes my  ground base to disappear though, to be fully replaced by the newly imported OBJ.
I was interested to know if there is a way to keep the base shape from disappearing. (Using the scatter rule instead keeps the base shapes, but the texture disappears from the ground shapes and get assigned to the OBJs which is not what I want to do, the object also appears at a random point on the surface and not in the centre).
Any help or advice is much appreciated
Thanks!What I am trying to do :)
LR
Create two rules, one for texturing the ground, one for inserting the object. Then just reference them both. Like
Lot -->
   GroundRule
   ObjectRule
LR
Lot -->
   GroundRule
   ObjectRule
CarlaBernecoli
Thanks! I'll try it
SerikRahimzhanovsss
hi! can u help me create rule with OBJ  file? pls
LR
It's not hard, you just i(nsert) the OBJ. Look here: i Operation
