Micah is correct, the points are a result of the segment network layer being turned on. You only want to show polygon models when showing street segments. Those points will appear in screen shots as well if you take them unless the segment lines are toggled off in the display.
Also judging by the number of breakpoints, your network might benefit from a simplify graph run.
David Wasserman, AICP
