Transparent Wall error
3226
02-27-2014 06:48 AM
by Anonymous User
Not applicable
Original User: briandev
I built a cube and selected the front and back and gave them both the color red.
But when I rotate around the cube the walls are transparent when watched from the back and red when I watch them from the front.
Here are the lines of the rule:
CubeMass-->
comp(f) {object.front:CubeFront|object.back:CubeBack}
CubeFront-->
color(1,0,0)
CubeBack-->
color(1,0,0)
I also provided two pictures.
anybody knows what is wrong?
cheers,
Brian
[ATTACH=CONFIG]31841[/ATTACH][ATTACH=CONFIG]31842[/ATTACH]
by Anonymous User
Not applicable
Original User: matthiasbuehler
based on the code, you only define front and back. Means top, left, right, bottom are not defined, thus don't generated actual geometry ( no geometry is not the same as transparent geometry .. 🙂 )
ok ?
m.
Briande_Vogel1
Sorry, maybe I should have wrote it down more clear 🙂
When I look at the wall from the front it's visible but when I rotate my camera and look at that same wall from the back it's transparent.
by Anonymous User
Not applicable
already solved the problem.
I disabled "Backface Culling" 🙂
by Anonymous User
Not applicable
ah..
ok.
that'd have been my next guess, since by default it's deactivated.
glad you found it ..
matt
