Text or Labels in City Engine
11490
24
04-08-2013 08:12 AM
JimJohnson2
Is there any way to use text or labels to identify the streets, buildings, etc...? Can someone point me to a tutorial or help menu for this.
MichaelWalton
I was about to try it on a project, but I discovered the 3D text rule didn't generate. The same 3D text rule works on my laptop which has CE 2014.0, but on my pc, I have CE 2014.1 and 3D text doesn't generate. There is an error that appears in the problems log "Error: geometry asset not found in ResolveMap"
And the warning looks like this in the log: [Method: 'Default$sx'] assetInfo(): assetInfo(): could not load file 'rules/3D_Text/For_3D_Text/Arial/3.obj' - returning 0.
by Anonymous User
Not applicable
I think something might have changed in between the two 2014 versions. I remember having a problem with this recently. I don't think CGA likes how I stored my assets in the rules folder. I'm not sure why I did that originally.
Try moving the "For_3D_Text" folder to your assets folder, and changing the "assetsDirectory" constant (1st line of code I think) to this:
const assetsDirectory = "assets/For_3D_Text/" + Font + "/"
Let me know if it works, and I'll update the download on my blog post.
Thanks!
Chris
MichaelWalton
Now it works...thank you for the quick fix
by Anonymous User
Not applicable
Awesome. I'll update the original asap!
MichaelWalton
Hey another awesome thing....if you export a scene with a 3D labels layer set as "backdrop", it will appear in the webscene and will not be present in layer table of contents.
