Sub-shape objects
1912
11-12-2013 02:32 AM
AleksandarLalovic
After spliting a shape with a rule file (using split command) i would like to trigger just a certain number of resulting elements, let say only 1 or 2. I tryied using the percent comand but i found it unreliable because if i split a shape into 10 objects and try to do something with 10% of those objects this would sometimes be 1, sometimes 3 and sometimes non of the objects.
Practical example:
My initial shape is a plot which i subdivide into footprints. I would like just one of these footprints to be a highrise and the rest 5 storie buildings (see the attachment). Idialy i should also be able to sear the position of it but that is a different topic i guess.
MatthiasBuehler1
Some things are not (yet) possible to synch/drive in just one step of model generation in CGA.
One example:
If you split a rectangle once through the shape, you always get 2 resulting shapes. If it's not a rectangle but a different concave form and you split it once, you may end up with multiple resulting shapes. that number ( the result ) can currently NOT be queried BEFORE the operation is actually performed. For this, CGA must be developed further a bit ( we're aware of this and considering to do so, of course).
So the current best practice is to some things in CGA and some manually, repectively automatted via Python.
Ok ?
Matt
AleksandarLalovic
Thanks Matt
Could i maybe select such splited shapes in python somehow. I ran into a comand some days ago but im not sure if it can do what i hope it can:
ce.getObjectsFrom(ce.scene, ce.withName("*Footprint*"))
So for example:
attr height = 20
Lot --> split(x){ ~5:Footprint}*
Footprint--> extrude(attr height)Mass.
Is it theoreticaly possible to get "Footprint" array in python and then overwrite "height" attribute of just one of these objects in array?
MatthiasBuehler1
Yes, things like this are possible. I discussed such workflows with your collegue last year.
We can discuss the option when we meet next time, ok ? 🙂
matt
AleksandarLalovic
Yes, sound great. See you then.
