Starting from a satelite image
2254
03-19-2014 04:06 PM
EzequiasRodrigues_da_Rocha
Hello everyone
I am new on CityEngine and I would like to start a model based on a satelite image and not from scratch. Is it possible? There is any document i can look?
PS: My idea is to build a before and after (proposition module) of my town.
Regards
Ezequias Rocha
LukeCzar
Hi
You should look through the "General Discussion" If I remember, there was a post about "tailing" the map together in order to get good quality map,
If you are new, I suggest to go through the posts and see what you can use in your project
If you would like to have existing\proposed conditions you should have 2 layers (1.existing, 2. existing + proposed, OR it depends on your project for instance if you are going to demolish some of the existing buildings then 1.existing, 2. existing-after demolition + proposed)
[[[   If you will have 1.existing, 2 proposed then in a WebScene you will have one or another ]]]
In order to get a "slide bar" when you export to WebScene name those 2 layers [existing, existing+ proposed] with the same name
To start the project check the attachment
[ATTACH=CONFIG]32476[/ATTACH]
LukeCzar
Also one more thing,
It is a good practice to download Tutorials and Examples (see attachment)
I guess there is a Slide Bar in Philadelphia Example
then you can check how they organized the Layers , select some area go to File Export--> WebScene and you will see their setting
Good Luck
Lukasz[ATTACH=CONFIG]32477[/ATTACH]
Good Luck
Thanks Lukaszczar
I will try your suggestion. I don't have any remote sensoring images but I got my area from google just to draw a draft.
What do you think of it? Should I add the parcels and buildings on ArcMap ant than import the geodatabase and the non-retified image to CityEngine?
Regards
Ezequias Rocha
