Own Exporter
2324
04-24-2014 05:30 AM
MathiasHuebscher
I want to export my generated Models to an own data format. Is it possible to get access to the needed data (vertices, normals, materials, textures, uv-coords...) in a python script?
If this is not possible: Is it possible to write an own exporter plugin?
Thank you for answers
Tags (3)
MatthiasBuehler1
Hi !
Yes, this is possible with the CityEngine SDK:
https://github.com/Esri/esri-cityengine-sdk
Ok ?
matt
MatthiasBuehler1
Hi !
Ok ?
matt
MathiasHuebscher
Thank you this is all I need!
