split parapet walls
5854
09-07-2015 11:43 PM
AidaAfrooz
Hello,
Does anyone know which operation I need to use to split the parapet wall of the building attached similar to the Google image?Thanks!
BenLeslie1
I had a go and this looked pretty good to me - I'm not sure you'll get the sizes identical unless each wall is the same length.
Lot-->
extrude(10)
comp(f){top:Top|side:Sides.}
Top-->
offset(-0.5)
comp(f){inside:Roof.|border:Battlement}
Battlement-->
split(x){~1:Merlon|{~2:Crenel.|~2:Merlon}*|~2:Crenel.|~1:Merlon}
Merlon-->
extrude(2)
(edited to correct terminology)
BenLeslie1
I think this section of CE documentation should help
split Operation
Unless I misunderstand what youre asking..
MatthiasBuehler
Did you have a look at the official tutorial 9?
CityEngine Tutorials - Tutorial 9: Advanced shape grammar
This will give you a good intro in how to tackle your specific building..
Good luck!
Matt
Matthias Buehler
Head of 3D Technologies
twitter: @MattB3D
Garsdale Design Limited
[email protected]
www.garsdaledesign.co.uk
AidaAfrooz
Hi Ben and Matthias,
Thanks for your reply.
I tried split operation but was not successful to make the crenellation or the gap between the splits equally.
I looked at the tutorial before but will double check it and go through it again.
in case you came up with any ideas in making the crenellation for parapet walls, please let me know!
thanks
BenLeslie1
Lot-->
extrude(10)
Top-->
offset(-0.5)
Battlement-->
Merlon-->
extrude(2)
AidaAfrooz
Thank you very much Ben!! It works
