set problem
841
12-25-2019 06:43 PM
chojeo
i made this cga
but there is porblem
"  set(Facade_Textures.Usage , "Agricultural") "
" set(Facade_Textures.Usage , "Office")"
did not working well
that did not apply
what problem
import FFacade_Textures   : "/ESRI.lib/rules/Facades/Facade_Textures.cga" () # completely controlled in rules below
 @StartRule
Lot -->
 case geometry.area < 100   :
    extrude (10) Stories
    else:
  extrude (20) Stories
Stories -->
 comp(f){ side: Facade }
Facade -->
 Facade_Textures.Generate
CherylLau
First, there is a typo, which results in a compile error.  In the import line, you probably wanted to write Facade_Textures instead of FFacade_Textures.
Second, set() only sets Facade_Textures.Usage, but Facade_Textures.GroundfloorTexture and Facade_Textures.UpperfloorsTexture also need to be set.  This is because set() only changes the specified attribute and does not change other attributes.  The other attributes are initialized before any rules are derived, so when you call set() on Facade_Textures.Usage, the other attributes will have the values that they were initialized with.  You need to set these attributes as well since getting the correct texture depends on them.
set(Facade_Textures.GroundfloorTexture, Facade_Textures.getGroundfloorTexture)
set(Facade_Textures.UpperfloorsTexture, Facade_Textures.getUpperfloorsTexture)
