Select Streets or Sidewalks based on width
1723
07-05-2022 02:22 AM
MattOlsen
Hi all,
I'm hoping this one is relatively straightforward - I've looked through documentation and articles but couldn't quite find an answer.
I'm looking to automatically select streets or sidewalks based on their widths (actually, within a certain range of widths), so I can apply certain attributes using the complete streets rules.
This seems like a job for a python script?
Wondering if any has any suggestions for this.
Matt
plfontes
Hi Matt,
hereunder a python script to select graph segments by streetWidth attribute, just replace the min and max values (without quotes) in the last line by your desired range values:
Created on 06 Jul 2022
@author: PFontes
from scripting import *
# get a CityEngine instance
ce = CE()
def selectByAttribute(attr, minValue, maxValue):
    objects = ce.getObjectsFrom(ce.scene, ce.isGraphSegment)
    selection = []
    for item in objects:
        attribute = ce.getAttribute(item, attr)
        if attribute >=  minValue and attribute <= maxValue:
                selection.append(item)
    ce.setSelection(selection)
if __name__ == '__main__':
    selectByAttribute("/ce/street/streetWidth", "(minimum value inclusive)", "(maximum value inclusive)")
Hope this is what you're looking for.
MattOlsen
@plfontes - thank you for the quick response on this. This does look like what I'm looking for, however it isn't currently working so I think I'm missing a step somewhere along the way..
I've created a new python module (with your code), in the same cityengine project as the scene file - for testing's sake I've tried very large values (0 to 1500) and smaller ones (0 to 15).
When I run the script (Python > Run Script?), no streets are selected. In the screenshot below I've manually selected one of the streets with a width of 10, so this should in theory be selected by the script.
Can you see any steps I've missed here?
plfontes
Yes, my bad.
just include a "/" at the beginning of the attribute name in the last line to look like this "/ce/street/streetWidth"
Should work now.
MattOlsen
Works like a charm. Thank you!
