Save snapshot only exports lower left part of viewport
2283
10-10-2014 12:18 AM
BrunoSeiler
When I use save snaphot it only exports the lower left part of the viewport (see attached pics).  I am working on a Mac with OSX 10.9.5 with Retina display and the issue appears with both CityEngine versions 2013.1 and 2014.1. However I didn't have this issue with my older Mac with a slightly older OSX and without Retina display. Any idea why this happens and how I could solve it?
MatthiasBuehler
Hi Bruno,
I heard from Roman you're talking about screenshots in python.. or is it the same via the UI ?
Just to make sure ..
Matthias Buehler
Head of 3D Technologies
twitter: @MattB3D
Garsdale Design Limited
matthias.buehler@garsdaledesign.co.uk
www.garsdaledesign.co.uk
BrunoSeiler
Hi Matt
Small World :-). We have exactly the same issue in the UI and in python...
MatthiasBuehler
I tried here and it seems to work fine .. both via UI and python ..
strange.. does this happen in each and every snapshot you take ?
m.
Matthias Buehler
twitter: @MattB3D
BrunoSeiler
Hmm.. Yes, it happens with every snapshot. It's definitely related to the mac retina display. I found a workaround on the apple website in the meantime. You need to open cityengine in low-resolution mode when you want to export snapshots and then it works fine:
  • Quit the application if it is currently open.
  • In the Finder, choose Applications from the Go menu.
  • In the Applications folder that opens, click the application's icon so it is highlighted.
  • Choose Get Info from the File menu.
  • Place a checkmark next to "Open in Low Resolution" to enable Low Resolution mode.
  • Close the window and double click the Application to reopen it.Note: You may also contact the developer of the application to determine if they are offering an update to the application for the Retina display.
So I guess this means that you can't work in the high-resolution mode when you want to export snapshots. Fortunately the rest of the functionalities in CityEngine seem to work fine in both modes.
Thanks for your help!
MatthiasBuehler
ah, Retina, ok.
I'll make sure the devs see this.
good you have a workaround for now.
cheers !
Matthias Buehler
twitter: @MattB3D
