Roof orientation - does CityEngine forget?
3155
08-30-2013 01:11 AM
BenLeslie1
Hi
I have drawn 440 building footprints in CityEngine.  I have taken care with the edge I have drawn first to help me control the orientation of gable and shed roofs.  In case I have made a mistake with the first edge I have added a 'roofIndex' attribute so I can change the orientation of the roof where necessary.
I have found that when I re-open the project some of the roofs have changed their orientation since I saved the file - I'm not sure how many buildings have changed because the effect is mainly quite subtle but in the case of long-thin buildings with a shed roof the effect is very obvious because the roof becomes enormous.
Is this a known problem (2011.2)?
Does CityEngine forget which edge was drawn first?
Does it forget the change to my 'roofIndex' parameter?
Would it remember the first edge better if I used imported shapefiles?
Could I be doing something wrong?
It's very difficult for me to spot a pattern to this because it's difficult to be sure where it is happening.
MatthiasBuehler1
Hi Ben,
Can you test this with an installation of the CityEngine 2012 TRIAL ?
I'm not perfectly sure if this was a specific 2011 bug.
Can you track this down to a very simple rule and 1 building which reproduces the issue ?
Let me know.
matt
BenLeslie1
I'm afraid I'm not getting CE 2012 trial to work - it just hangs on the splash-screen.
I think I meet minimum system requirements...I have:
Windows XP Professional x64 Service Pack 2.
NVIDIA Quadro 2000
I've rebooted since I installed it.....any suggestions?
(The machine on which I have 2011.2 installed is not connected to the internet so I trying to install this on a different one).
BenLeslie1
I'm sorry, I forgot I was mucking about with the convexify command at the beginning of my cga file......it's all my fault.
This thread can be deleted if you like.
MatthiasBuehler1
this could be a few things..
please write to [email protected] , ok ?
m.
