To import Collada .dae files
1919
08-29-2013 06:08 AM
FloreStuby
Hi ,
When opening the "import" window I do not have a selection for DAE Import ( I'm on CE Basic 2012.1) . I have a lot of 3D models imported through SUp in that format . Is there a trick ?
MatthiasBuehler1
http://www.esri.com/software/cityengine/buy/comparison-table
Check 'Advanced 3D Format Support'
Ok ?
Matt
FloreStuby
OK, well taken !
I found a solution for now through Archicad where I import .skp files and export them as .obj in CE . But for the next version of CE I may upgrade to "advanced" unless "basic" improves on that point.
Best regards,
Flore
MatthiasBuehler1
This won't change in CE 2013.
Note that the TRIAL version is the CE Advanced version, so this may help you if you need to 'save' some project files if you're stranded now.
Matt
FloreStuby
Hi Matt,
Thanks for the help !
Flore
