Remove vertex on line
6592
8
01-13-2015 08:56 AM
SteveRhyne
I created a road and without re-drawing the road I want to remove a vertex. I hope it's not obvious how to remove a point but any help is appreciative.
Thanks.
Venkata_RaoTammineni
try this Insert/Delete Vertex programatically
Thanks and Regards,
Venkat
SteveRhyne
I'm not familiar where to enter your code. Where do I place it?
Thanks.
by Anonymous User
Not applicable
Is this a CityEngine question, or ArcGIS? In CityEngine this is not possible. I've wanted this also, so I just filed a feature request with the CE development team. So we may see it in an upcoming release. For now, just reconnect with a new road segment or connect the two leftover nodes.
SteveRhyne
CityEngine. Bummer! That surprises me CityEngine does not offer a common editing feature like that.
Thanks for the reply.
JanHalatsch
Hi Steve, your issue can probably be solved by applying the next three steps.
1. Activate the move tool by pressing the 'w' key
1. Select the node that you like to delete
2. Drag it with your mouse onto one of the two neighbouring nodes
Good luck & Have a great day!
Jan
by Anonymous User
Not applicable
Jan, Thank you for that!!!
You should visit the forum more often! You've used City Engine since it was birthed!
Chris
JanHalatsch
Thanks for the kind words. Happy to see you in Redlands next week!
SteveRhyne
That is awesome! When you move the vertex over the neighboring vertex you see the kind of mess it's going to make but it fixes itself. Very cool. Thanks!!!
