Insert/Delete Vertex programatically
7848
7
08-08-2011 03:36 AM
ChaesoonLim
I'd like to implement function to insert vertex on polyline just like in arcmap.
When mouse cursor is located on boundary snap on polyline, clicking right mouse button, select insert vertex on popup menu.
My code to insert vetex is something like this.
Dim pSelected As IEnumFeature = m_Map.FeatureSelection
Dim pFeature As IFeature = pSelected.Next()
Dim pGeom As IGeometry = pFeature.Shape
Dim pGeomColn As IGeometryCollection = pGeom
Dim pPath As IPath = pGeomColn.Geometry(partIndex)
Dim pPoints As IPointCollection = pPath
Dim Missing As Object = Type.Missing
Dim val As Object
If vertexIndex = 0 Then
       val = 1
       pPoints.AddPoint(pHitPoint, val, Missing)
Else
        val = vertexIndex
        pPoints.AddPoint(pHitPoint, Missing, val)
End If
Dim pGeom As IGeometry = pPoints
pFeature.Shape = pGeom
pFeature.Store()
At line pFeature.Shape = pGeom
Error occures like below.
"The feature object does not have a valid shaple."
Do I missed something else in code?
Any advice is OK.
DubravkoAntonic
try
Dim pGeom As IGeometry = pFeature.ShapeCopy // does cloning of the geometry
After you finish editing if you got error use
ITopologicaOperator2 IsknowSimple2 = false;
and call
IToplogicalOperator.Simplify();
ChaesoonLim
Thanks for your reply.
I changed  pFeature.Shape to  pFeature.ShapeCopy, but error occures as same.
About ITopologicaOperator2, actually I cann't understand what you mean because of my short knowledge...
If you write the code in detail, it'll be very thankful.
DubravkoAntonic
No problem at all. I'm not native Visual Basic or .Net Basic but will try to answer in VB.
I'm not sure where did pHitPoint came from, is it maybe part of some other geometry. If this is the case you should Clone geometry. Cloning Geometry is important because of reusing same reference and there fore using object from someone else geometry and two parent objects are referencing one object but only one is really using it as valid geometry element.
How to clone?
public static Function Clone(IPoint point) as IPoint[INDENT]Dim IClone cloner
cloner = point As IClone;
Set Clone = cloner.Clone as IPoint;
[/INDENT]Function End
More of cloning from SDK
http://resources.esri.com/help/9.3/arcgisengine/dotnet/9915ff7d-f119-47ed-b381-cf7dded5cd93.htm
Dim ITopologicaOperator2 pTopOp
Set pTopOp = pGeom as ITopologicaOperator2
pTopOp.IsknowSimple2 = false
pTopOp.Simplify
pFeature.Shape = pTopOp as IGeometry
pFeature.Store
ChaesoonLim
Thanks again for your kind explanation.
But I still have problem.
The pHitPoint is a boundary snapped point.
I called HitTest function to find out snapped point.
Dim pHitTest As IHitTest = pGeom
Dim pHitPoint As IPoint = New Point
pHitTest.HitTest(pPoint, tolerance, esriGeometryHitPartType.esriGeometryPartBoundary, pHitPoint, hitDist, partIndex, vertexIndex, bTrue)
And at the code "Set pTopOp = pGeom as ITopologicaOperator2",
error occures because the type of pGeom is IPointCollection not IPoint, I think.
Do you have any idea for resolve this problem?
NeilClemmons
Honored Contributor
According to your original code, you are getting a point collection from a path object, updating that point collection, then trying to assign the path object as the feature's shape.  You can't do that.  A path is not a high level geometry and cannot be used to assign a feature's shape.  You need to assign the shape using the original geometry reference you set at the beginning of the code.
DubravkoAntonic
Neil is right.
Your solution is there.
IPolyline.SplitAtPoint
http://resources.esri.com/help/9.3/ArcGISDesktop/ArcObjects/esrigeometry/IPolycurve_SplitAtPoint.htm
There is some info and example at the bottom.
It is useful.
Just some hint.
Create small static functions that does one thing and reuse them. with time you have your pretty powerful class.
That way your code will evolve become more readable.
ChaesoonLim
Thanks you, guys
I resolved this problem for your helps.
My code was changed something like below.
Dim pPoints As IPointCollection = pGeom
Dim val As Object
    val = 1
Else
    val = vertexIndex
End If
pFeature.Shape = CType(pPoints, IGeometry)
pFeature.Store()
Of course, as dubravko's comment, I created function in my own code.
Any Comment is OK.
Thanks.
