Using Geoprocessor clip with InMemoryWorkspaceFactory
3039
8
08-04-2011 05:46 AM
CarlosPiccirillo
Hi everyone,
I am trying to use InMemoryWorkspaceFactory with the Geoprocessor in an attempt to improve a slow part of program.
The code below runs fine if I use a file geodatabase so I know the logic is okay but as soon as I switch to trying to use an InMemoryWorkspaceFactory, the clip command produces no output and I don't get an error either.
The second method is what I am using to list all layers in the workspace and it only list the in and clip layers, not the output.
I've been trying stuff for two full days now and am out of ideas on what to try next.
Carlos
public static bool DetermineOverlapArea3(IFeatureLayer pAppLayer, IFeatureLayer pEnsLayer,
      IFeature pAppFeature, IFeature pEnsFeature)
    try
 IQueryFilter queryFilter = new QueryFilterClass();
 IDataset pDataset1 = null;
 IDataset pDataset2 = null;
 IFeatureSelection pFeatureSelection1 = null;
 IFeatureSelection pFeatureSelection2 = null;
 IFeatureClassName pInFeatureClassName1 = new FeatureClassNameClass();
 IFeatureClassName pInFeatureClassName2 = new FeatureClassNameClass();
 IDatasetName pInDatasetName1 = null;
 IDatasetName pInDatasetName2 = null;
 IFeatureClassName pOutFeatureClassName1 = new FeatureClassNameClass();
 IFeatureClassName pOutFeatureClassName2 = new FeatureClassNameClass();
 IDatasetName pOutDatasetName1 = null;
 IDatasetName pOutDatasetName2 = null;
 IWorkspaceFactory pWorkspaceFactory = new InMemoryWorkspaceFactoryClass();
 IFeatureLayer pFeatureLayer = new FeatureLayerClass();
 IFeatureWorkspace pFeatureWorkspace = null;
 IWorkspaceName pWorkspaceName = new WorkspaceNameClass();
 IFeatureClass pFeatureClass = null;
 pWorkspaceName = pWorkspaceFactory.Create("", "TEMP", null, 0);
 IName pName = pWorkspaceName as IName;
 IWorkspace pWorkspace = pName.Open() as IWorkspace;
 pFeatureWorkspace = pWorkspace as IFeatureWorkspace;
 if (pAppLayer != null)
     pFeatureSelection1 = pAppLayer as IFeatureSelection;
     queryFilter.WhereClause = "APP_NO = '" + m_AppNo + "'";
     pDataset1 = pAppLayer.FeatureClass as IDataset;
     pFeatureSelection1.SelectFeatures(queryFilter, esriSelectionResultEnum.esriSelectionResultNew, false);
     pInFeatureClassName1 = pDataset1.FullName as IFeatureClassName;
     pInDatasetName1 = pInFeatureClassName1 as IDatasetName;
     pOutDatasetName1 = pOutFeatureClassName1 as IDatasetName;
     pOutDatasetName1.Name = "APPTEMP";
     pOutDatasetName1.WorkspaceName = pWorkspaceName;
     pOutFeatureClassName1.FeatureType = esriFeatureType.esriFTSimple;
     pOutFeatureClassName1.ShapeType = esriGeometryType.esriGeometryAny;
     pOutFeatureClassName1.ShapeFieldName = "Shape";
     IExportOperation pExportOperation = new ExportOperationClass();
     pExportOperation.ExportFeatureClass(pInDatasetName1, null, pFeatureSelection1.SelectionSet, null, pOutFeatureClassName1, 0);
 if (pEnsLayer != null)
     pFeatureSelection2 = pEnsLayer as IFeatureSelection;
     queryFilter.WhereClause = "BASIN_NAME = '" + m_Label + "'";
     pDataset2 = pEnsLayer.FeatureClass as IDataset;
     pFeatureSelection2.SelectFeatures(queryFilter, esriSelectionResultEnum.esriSelectionResultNew, false);
     pInFeatureClassName2 = pDataset2.FullName as IFeatureClassName;
     pInDatasetName2 = pInFeatureClassName2 as IDatasetName;
     pOutDatasetName2 = pOutFeatureClassName2 as IDatasetName;
     pOutDatasetName2.Name = "ENSTEMP";
     pOutDatasetName2.WorkspaceName = pWorkspaceName;
     pOutFeatureClassName2.FeatureType = esriFeatureType.esriFTSimple;
     pOutFeatureClassName2.ShapeType = esriGeometryType.esriGeometryAny;
     pOutFeatureClassName2.ShapeFieldName = "Shape";
     pExportOperation.ExportFeatureClass(pInDatasetName2, null, pFeatureSelection2.SelectionSet, null, pOutFeatureClassName2, 0);
 ESRI.ArcGIS.AnalysisTools.Clip pClip = new ESRI.ArcGIS.AnalysisTools.Clip();
 pClip.in_features = pWorkspace + "APPTEMP";
 pClip.clip_features = pWorkspace + "ENSTEMP";
 pClip.out_feature_class = pWorkspace + "APP_ENS_OVERLAP";
 ITrackCancel pTrackCancel = new CancelTrackerClass();
 pTrackCancel.CancelOnClick = false;
 pTrackCancel.CancelOnKeyPress = true;
 ESRI.ArcGIS.Geoprocessor.Geoprocessor pGeoprocessor = new ESRI.ArcGIS.Geoprocessor.Geoprocessor();
 pGeoprocessor.Execute(pClip, pTrackCancel);
 //Get the resulting intersection polygon.
 pFeatureClass = pFeatureWorkspace.OpenFeatureClass("APP_ENS_OVERLAP");
 pFeatureLayer.FeatureClass = pFeatureClass;
 IFeatureSelection pFeatureSelection = pFeatureLayer as IFeatureSelection;
 pFeatureSelection.SelectFeatures(null, esriSelectionResultEnum.esriSelectionResultNew, false);
 ISelectionSet pSelectionSet = pFeatureSelection.SelectionSet as ISelectionSet;
 ICursor pCursor;
 pSelectionSet.Search(null, true, out pCursor);
 IFeatureCursor pFeatureCursor = pCursor as IFeatureCursor;
 IFeature pIntersectFeature = pFeatureCursor.NextFeature();
 IArea pIntersectArea = pIntersectFeature.Shape as IArea;
 IArea pAppArea = pAppFeature.Shape as IArea;
 IArea pEnsArea = pEnsFeature.Shape as IArea;
 int appOverlap = Convert.ToInt32((pIntersectArea.Area / pAppArea.Area) * 100);
 int ensOverlap = Convert.ToInt32((pIntersectArea.Area / pEnsArea.Area) * 100);
 if (appOverlap > 5 || ensOverlap > 5)
     return true;
 else
     return false;
    catch (Exception ex)
 LogError(ex.StackTrace, ex.Message, "DetermineOverlapArea", null);
 return false;
IEnumDataset pEnumDataset = pWorkspace.get_Datasets(esriDatasetType.esriDTFeatureClass) as IEnumDataset;
IDataset pDataset = pEnumDataset.Next();
while (pDataset != null)
    MessageBox.Show(pDataset.Name);
KenBuja
MVP Esteemed Contributor
I haven't tried using the IMemoryWorkSpaceFactory, but I have been able to use a geoprocessor process parameter like
"in_memory\output"
CarlosPiccirillo
Ken,
Thanks for the reply. I saw something about that in the documentation but could not get it to work either. Do you have some sample code in any language I can look at that uses "in_memory"?
Thanks for your time.
Carlos
"in_memory\output"
KenBuja
My code makes calls to functions containing the geoprocessing tools. I've declared the geoprocessor Global.GP in another module and initialized it elsewhere
pDissolvedFClass = DissolveDataset(pResourceFClass, DissolveFieldName, StatisticsFieldName & " " & Stat, "in_memory\DissolvedResource")
    Friend Function DissolveDataset(ByVal InputName As Object, ByVal DissolveField As String, ByVal StatsFields As String, ByVal OutputName As String) As ESRI.ArcGIS.Geodatabase.IFeatureClass
        Dim DissolveDS As New ESRI.ArcGIS.DataManagementTools.Dissolve
        Dim Result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2
        Try
            Using releaser As New ESRI.ArcGIS.ADF.ComReleaser
                releaser.ManageLifetime(DissolveDS)
                DissolveDS.in_features = InputName
                DissolveDS.dissolve_field = DissolveField
                DissolveDS.statistics_fields = StatsFields
                DissolveDS.out_feature_class = OutputName
                Result = RunTool(DissolveDS, Nothing)
                If Result Is Nothing Then
                    System.Windows.Forms.MessageBox.Show("Could not dissolve dataset")
                    Return Nothing
                End If
                Return ReturnObjectfromResult(Result, "Feature Class")
            End Using
        Catch ex As Exception
            System.Windows.Forms.MessageBox.Show(ex.ToString, "Dissolve error")
            Return Nothing
        End Try
    End Function
    Friend Function ReturnObjectfromResult(ByVal result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2, ByVal Type As String) As Object
        Dim GPVal As ESRI.ArcGIS.Geodatabase.IGPValue
        Dim InMemFC As String
        Dim GPUtil As ESRI.ArcGIS.Geoprocessing.IGPUtilities3 = New ESRI.ArcGIS.Geoprocessing.GPUtilities
        Try
            GPVal = result.GetOutput(0)
            InMemFC = GPVal.GetAsText()
            Select Case Type
                Case "Feature Class"
                    Return GPUtil.OpenFeatureClassFromString(InMemFC)
                Case "Table"
                    Return GPUtil.OpenTableFromString(InMemFC)
            End Select
            System.Windows.Forms.MessageBox.Show(ex.ToString, "Return FeatureClass error")
            Return Nothing
        End Try
    End Function
    Private Sub ReturnMessages(ByVal pResult As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2, ByVal Title As String)
        Dim ErrorMessage As String
        If pResult.MessageCount > 0 Then
            For Count As Integer = 0 To pResult.MessageCount - 1
                ErrorMessage += pResult.GetMessage(Count)
        End If
        System.Windows.Forms.MessageBox.Show(ErrorMessage, Title)
    End Sub
    Friend Function RunTool(ByVal Process As ESRI.ArcGIS.Geoprocessor.IGPProcess, ByVal TC As ESRI.ArcGIS.esriSystem.ITrackCancel2) As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2
        Try
            Result = CType(Globals.GP.Execute(Process, Nothing), ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2)
            If Result.Status <> ESRI.ArcGIS.esriSystem.esriJobStatus.esriJobSucceeded Then ReturnMessages(Result, "Geoprocessing Error")
            Globals.GP.ClearMessages()
            ReturnMessages(Result, "Fail")
            System.Windows.Forms.MessageBox.Show(ex.ToString, "Run Geoprocessor")
        End Try
        Return Result
    End Function
CarlosPiccirillo
Ken,
Thanks for sample code. Looking at your code, I got mine to work. Unfortunately, I am still having one issue. The methos below gets called from a loop. The first time the method gets called everything works fine. The second time however, the line below retuns null.
GeoProcessorResult result = pGeoprocessor.Execute(pClip, null) as GeoProcessorResult;
Any idea why this is happening?
Carlos
            try
                IFeatureClass pAppFeatureClass = pFeatureWorkspace.OpenFeatureClass("APPTEMP");
                IFeatureClass pEnsFeatureClass = pFeatureWorkspace.OpenFeatureClass("ENSTEMP");
                //Execute clip.
                Clip pClip = new Clip();
                pClip.in_features = pAppFeatureClass;
                pClip.clip_features = pEnsFeatureClass;
                pClip.out_feature_class = "in_memory\\APP_ENS_OVERLAP";
                Geoprocessor pGeoprocessor = new Geoprocessor();
                IGPValue pGPValue = result.GetOutput(0);
                string InMemoryFeatureClass = string.Empty;
                InMemoryFeatureClass = pGPValue.GetAsText();
                //Get resulting feature class.
                IGPUtilities pGPUtilities = new GPUtilities();
                IFeatureClass pOverlapEnsFeatureClass = pGPUtilities.OpenFeatureClassFromString(InMemoryFeatureClass);
                pFeatureLayer.FeatureClass = pOverlapEnsFeatureClass;
                ICursor pCursor;
                    return true;
                else
                    return false;
                return false;
KenBuja
Hi Carlos,
I'm glad to hear you're making progress. Since you don't have the code to show why the Clip process didn't run, examine the Results information in ArcMap to find out what happened. Could it be that it's not overwriting "in_memory\APP_ENS_OVERLAP"? Have you set the Geoprocessor to overwrite outputs, either through the Geoprocessing Options dialog or by setting
pGeoprocessor.OverwriteOutput = "true"
CarlosPiccirillo
Hi Ken,
Thanks for the reply. You are right on, I did not have pGeoprocessor.OverwriteOutput = "true" set. I added that line to the code below and now it gets further along but after a couple hundred records or so, it starts failing every time the method below gets called (inside loop of another method) and the error is "Object reference not set to an instance of an object." I know what's happening, but no clue as to why. The problem occurs because line:
suddenly stops returning a selection set. This line should always return something because the method only gets called when a spatial query determines that two polygons from different layers intersect each other so I don't understand why suddenly it stops working. Sounds like a memory leak or object not being cleared correctly but I've tried adding lines like, if (pWorkspaceFactory != null) { Marshal.ReleaseComObject(pWorkspaceFactory); pWorkspaceFactory = null; } for every object to clear it but it doesn't help. I can post the method calling this method if you want. Just have to do it in another message because it's too large to fit in this one.
Thanks again for your help and time, I appreciate it!!!
            try
                //Execute clip.
                pGeoprocessor.AddOutputsToMap = false;
                pGeoprocessor.OverwriteOutput = true;
                IGeoProcessorResult result = pGeoprocessor.Execute(pClip, null) as IGeoProcessorResult;
                IFeatureClass pOverlapEnsFeatureClass = pGeoprocessor.Open("in_memory\\APP_ENS_OVERLAP") as IFeatureClass;
                ISelectionSet pSelectionSet = pFeatureSelection.SelectionSet as ISelectionSet;   //PROBLEM HERE
                ICursor pCursor;
                    return true;
                else
                    return false;
                MessageBox.Show(ex.Message);
                //LogError(ex.StackTrace, ex.Message, "DetermineOverlapArea", null);
                return false;
Hi Carlos,
DuncanHornby
MVP Notable Contributor
May be a bit late in this discussion but I was playing around with creating in_memory workspaces in VBA (ArcGIS 9.3). Here is my code.
Public Sub InMemoryExample()
 ' Description: Sample code showing how an in memory table can be created
 ' Create Workspacefactory
 Dim pWorkSpaceFactory As IWorkspaceFactory2
 Set pWorkSpaceFactory = New InMemoryWorkspaceFactory
 ' Create Workspace
 Dim pWorkspaceName As IWorkspaceName2
 Set pWorkspaceName = pWorkSpaceFactory.Create("", "MyInMemoryWorkspace", Nothing, 0)
 ' Get a handle on Name
 Dim pName As IName
 Set pName = pWorkspaceName
 ' Get a handle on FeatureWorkspace
 Dim pFeatureWorkspace As IFeatureWorkspace
 Set pFeatureWorkspace = pName.Open
 ' Now create a fields object and add some fields to it
 ' Create Fields object and set the number of fields
 Dim pFields As IFields
 Set pFields = New Fields
 Dim pFieldsEdit As IFieldsEdit
 Set pFieldsEdit = pFields
 pFieldsEdit.FieldCount = 2
 ' Create objectID field
 Dim pField As IField
 Set pField = New Field
 Dim pFieldEdit As IFieldEdit
 Set pFieldEdit = pField
 With pFieldEdit
 .Name = "OBJECTID"
 .Type = esriFieldTypeOID
 End With
 Set pFieldsEdit.Field(0) = pField
 ' Create Type field
 With pFieldEdit
 .Editable = True
 .Name = "VegType"
 .Type = esriFieldTypeString
 .Length = 4
 .AliasName = "Vegetation Type Code"
 End With
 Set pFieldsEdit.Field(1) = pField
 ' Create Table
 Dim pTable As ITable
 Set pTable = pFeatureWorkspace.CreateTable("MyInMemTable", pFields, Nothing, Nothing, "")
 ' Create a sample row and add data
 Dim pRow As IRow
 Set pRow = pTable.CreateRow
 With pRow
 .Value(1) = "WOOD"
 .Store
 End With
 ' Add table to map document
 Dim pMXD As IMxDocument
 Set pMXD = ThisDocument
 Dim pMap As IMap
 Set pMap = pMXD.FocusMap
 Dim pStandAloneTableCollection As IStandaloneTableCollection
 Set pStandAloneTableCollection = pMap
 Dim pStandAloneTable As IStandaloneTable
 Set pStandAloneTable = New StandaloneTable
 Set pStandAloneTable.Table = pTable
 pStandAloneTableCollection.AddStandaloneTable pStandAloneTable
 pMXD.UpdateContents
End Sub
Duncan
CarlosPiccirillo
Thanks Duncan, I appreciate it. 🙂
