Reflection on textures
1472
08-20-2014 12:52 PM
KennethLindhardt
I’ve tried this set(material.reflectivity, 0.1)  That don’t give me anything, no matter what value I use. Is it possible to get reflection inside a webscene?
MatthiasBuehler
hi ..
reflection works best in conjunction with the other specularity settings.
and 0.1 is almost nothing. try a higher value..
check the values in the instance city example. they may be extreme, but get you going.
matt
KennethLindhardt
Thank you Matt. I did try any reflectivity amount. But for some reason it worked after I restarted my machine. It was probably something with my graphic card, since it was running very strange.
MatthiasBuehler
Hmm. okay.
Maybe also try to make sure you're working on the latest driver.
Kind greetings !
Matt
