Random Texture with Inspector Override
1817
09-04-2020 04:37 PM
BenHammer1
Hello CE Community,
I'm looking for a way to override randomized textures. It would be nice to have the ability to change the textures with a drop-down menu in the inspector.
Thanks.
DevinLavigne
Just use a stochastic rule in your attribute. This will randomize on seed generation and then give you the ability to change it.  Something like the code below should work.
@Enum("texA.jpg","texA.jpg","texC.jpg","texD.jpg")
attr Texture =  25%: "texA.jpg"
                25%: "texB.jpg"
                25%: "texC.jpg"
               else: "texD.jpg"‍‍‍‍‍‍‍‍‍
by Anonymous User
Not applicable
I think you are trying to activate browse tool.
I use the texture folder wildcard method:
attr wall_tex = getWallTexture
getWallTexture  = listRandom(_getWallTexture)
_getWallTexture = fileSearch("/FolderDestination*" + "*.*")
Then over in the inspector you should be able to access the "browse" to override your texture:
I also think you can activate the browse by simply adding the "@File" before your attribute rule (?).
CherylLau
Yes, that is correct.  The @File annotation allows you to open a file chooser.
Annotations—ArcGIS CityEngine Resources | Documentation
