Python code: Selecting all objects with one attribute
3317
05-03-2023 08:18 PM
AlexWierzbicki
Hoping that someone can help me out. I am a python newbie and I am trying to create a script that will select all objects that have the Object Attribute "amenity" equal to "school". Could some please help me identify what is wrong with the below code?
from scripting import *
# get a CityEngine instance
ce = CE()
def selectByAttribute(attr, value):
    objects = ce.getObjectsFrom(ce.scene)
    selection = []
    for item in objects:
        attribute = ce.getAttribute(item, attr)
        if attribute == value:
                selection.append(item)
    ce.setSelection(selection)
if __name__ == '__main__':
    selectByAttribute("/ce/geometry/amenity", "school")
JonasObertuefer
hi again,
  • @noUIupdate needs to be directly above the function you want to trigger no UI updates
  • change the filter in your getObjectsFrom() from ce.isGraphSegment to ce.isShape. Amenity is isuallay a object attribute assigned to shapes.
I tested the the code below, and it works for me:
ce = CE()
@noUIupdate
    objects = ce.getObjectsFrom(ce.scene, ce.isShape)
    selection = []
    selectByAttribute("amenity", "school")
MJF
Remove /ce/geometry/ and it should work
JonasObertuefer
Hi @AlexWierzbicki,
For a python newbie you got already quite far 😉
For object attributes you don't need any prefix just write selectByAttribute("amenity", "school") and your script should work.
I suggest two other small improvements to your script:
  • Add @noUIupdate before your function. This makes sure the UI will be refreshed only after the function is run through. Depending on the size of the scene and what your function does this can speed up the run significantly
  • In your case you don't need to query all objects from the scene, you can limit it to shapes only if you write objects = ce.getObjectsFrom(ce.scene, ce.isShape)
Cheers,
Jonas
AlexWierzbicki
I've made the suggested changes but unfortunately it is still not working, receiving either the following error or nothing at all happening, depending on where I put the @noUIupdate
Below is the code. Any other advice?
@noUIupdate
ce = CE()
    objects = ce.getObjectsFrom(ce.scene, ce.isGraphSegment)
    selection = []
JonasObertuefer
hi again,
ce = CE()
@noUIupdate
    selection = []
