Original User: matthiasbuehler
Hi Erin,
yes, CityEngine was designed originally for just building creation. After Esri having acquired us ( Procedural Inc. ), we basically just started with the proper integration into the world of GIS.
CityEngine has it's applications currenlty mostly above terrain, but we're constantly improving the tool, of course.
1 other idea:
instead of adding the cylinders in ArcGIS, you could insert 1 quad ( rectangular polygon ) in ArcGIS ( length = line length, width = 0.005 m). this way, you can create one polygon to all lines you have in one step.
then, since CGA NEEDS a geometry ( shape ) to work on, just import those attributed polygons into CityEngine and insert a cylinder there. of course, you'd bring in the cylinder diameter attribute and scale the cylinder in CGA.
makes sense ?
matt
