Models "moved" when exported to 3D web scene
2613
01-21-2014 03:04 AM
OlaSvensson
Hello!
I have run into a bit of an issue when exporting from CityEngine to 3D Web Scenes... It seems as if models in some layers are "moved" in different directions. I have attached two screenshots to show what I mean (please ignore the lack of textures and details ;)).
Is this a known bug, or am I simply missing some necessary step in the export?
I tried narrowing down the potential culprit of the issue, with no luck. I tried:
  • 2 different coordinate systems
  • Exporting just a single building and its corresponding roof (stored in a different file, note that all shapes are stored in shape files with the same projection)
  • Exporting with and without the terrain layer
  • Exporting with and without attributes/object interaction/metadata
  • Exporting both with and without "Geometry as Base64"
I'm running 2013.1, and I don't think the issue existed in 2012, but I'm not quite certain. It's possible that I missed it...
Anyway: Does anyone know of a workaround to the issue? If not, is it possible to get a hold of a copy of version 2012? I�??d like to show my colleagues how much we could increase our dialog with customers etc. by using 3D online, and this bug isn�??t really helping my case�?� 😉
[ATTACH=CONFIG]30651[/ATTACH][ATTACH=CONFIG]30649[/ATTACH][ATTACH=CONFIG]30650[/ATTACH]
EDIT:
I just found these two threads, which seem to be dealing with the same or similar issues:
http://forums.arcgis.com/threads/99404-Some-objects-are-slipping-when-I-share-the-model-on-Web-Scene
http://forums.arcgis.com/threads/99307-Polygons-seems-separate-on-web-scene-but-that-are-snapping-ea...
Shame on me for not looking hard enough. Seems like this is a known bug in 2013. Any chance of a trial version of 2012 being available? 🙂
Tags (3)
by Anonymous User
Not applicable
Original User: matthiasbuehler
Hi !
I've heard the request before and hope this is happening soon.
I've forwarded an other reminder.
Thanks for reporting !
matt
MatthiasBuehler1
Hi Ola !
Nevertheless, would it be possible that you provide a small dataset on which I can reproduce the issue here ?
Would be really helpful ..
Older TRIALS :
http://forums.arcgis.com/threads/101930-Accessing-older-CityEngine-TRIAL-versions
Matt
by Anonymous User
Not applicable
Original User: olasve
Hi Ola !
Older TRIALS :
Matt
Absolutely. I have attached a single building and the roof (exported from CE). Originally they were located in two different files, but I joined them for simplicity. Let me know if the attached building suffices, or you need more data (or in a different format, etc.). Cheers for the help!
by Anonymous User
Not applicable
can you also post a rule and before / after screenshots ?
let me know ..
[ EDIT : never mind, I can repro ]
Matt
