Insert a Tree on a texture
1789
03-13-2021 12:37 PM
JOELBEALE
Hi City Engine Community,
I am new to cga coding and I am trying to do something simple.
I am looking to apply a texture to a lot and insert a tree or multiple trees on top of the texture.
Here is what I have now:
Lot -->
primitiveQuad(1920,1080)
comp(f) {top:SATimage}
SATimage-->
texture("images/Satellite Imagery/Test Test/sattest.png")
Generate-->
alignScopeToAxes(y)
s(0,0,0)
t(x,z,y)
i(Tree)
________________________________________________
For some reason the tree either doesn't insert or the texture doesn't work. I cant get both to work at the same time.
Is there anyone that could help me with this coding?
Tags (3)
DevinLavigne
You can call your Generate rule from your Lot. I think the cleanest way to would be to put it on top and I would give it a more distinct/memorable name. The code below should work and will scatter 100 trees.
Lot -->
InsertTrees
comp(f) {top:alignScopeToAxes(y) SATimage | all: NIL}
SATimage-->
InsertTrees-->
scatter(surface, 100, uniform){PlantTree}
PlantTree-->
i(Tree)
JOELBEALE
When I saw your post I was surprised. I cant believe Mr. Lavigne replied to my post! I've admired your work ever since I discovered City Engine. You have a very impressive background with CE and your CGA coding skills are amazing. I have been persistent on learning how to code in City Engine and have been reading the online manual. The code above that you wrote really helped, I was stuck and was frustrated that I couldn't come to figure out how to insert a tree or an object on top of a texture. I really want to become an Urban Planner like you and have been interested in working for Houseal Lavigne Associates. I am a detail oriented Industrial Designer who is determined.
Below is my portfolio:
https://www.coroflot.com/creativeintuition/Joel-Beale-Portfolio-2020
