Can't Get a Custom Attribute under Object Attributes using Python
1148
03-18-2021 01:35 AM
CL11
In CityEngine 2019,
I'm trying to get an Object Attribute under a Shape's Object Attribute area.  The Object Attribute is populated with custom Fields from an SHP's DBF.  For Example: The attached picture shows the custom Object Attribute, CODE.
I tried using python to access this Object Attribute, but the printed result is "None".
    object = ce.getObjectsFrom(ce.scene, ce.withName("*Shape*"))
    print(ce.getAttribute(object[0], 'CODE'))
How can I get access to these custom Object Attribute fields from the shape?
